- therinkExplorerWhen I am at a campground where I am unfamiliar with the water pressure I sometimes fill my tank when I arrive and run off that and refill as needed. My pump works as well as City hook up and I trust it. Also I have been at campgrounds where the water system went down and didn't have water for extended periods. I can always count on my water system.
- HappyKayakersExplorer
Tequila wrote:
It is always best to use the tank & pump. If you see the number of threads here on disasters from city water hookups, you will understand why.
Very interesting. Been fulltiming since '06, same rig, always hooked up to city water when available, no disasters yet. - TequilaExplorerIt is always best to use the tank & pump. If you see the number of threads here on disasters from city water hookups, you will understand why.
- RedRocket204ExplorerNo. The water pressure from the city water feeds your system. The pump on the RV only pumps and pressurizes from your fresh holding tank.
44,025 PostsLatest Activity: Feb 06, 2025
