i am almost posative i blew the o ring on it while winterizing... my question is do i need to replace it? We are seasonal so we only use city water not fresh water from tank.Thank you
I would gut the internals so that they don't jam and end up restricting flow. Hate those cheap plastic junk check valves. Nothing but a plastic plunger/spring/o-ring assembly held in place by a clip on backside.
Then after guts are removed screw a a 90* elbow and a garden shutoff valve on and be done with issues. Just shut valve when you want to use pump..simple
