- 7404162081Explorer II
Vinegar will work just as well and is not caustic - Just don't over do it.
- normanthegr8Explorer II
Thank You,
- StirCrazyModerator
do the hot water tank first, the flush it out good, then do the bleach. I am not a fan of bleach anymore but lots of people use it so do it last after everything is clean, then flush the heck out of it after to get rid of the "bleach" most rv drain lines are 1/2" pex, but there could always be an exception.
- opnspacesNavigator III
Well if the water lines are standard red and blue PEX lines it is probably a half inch line. Aside from that we're all just guessing.
I would personally clean first and then sanitize.
That's what I was Thinking originally
- Grit_dogTrailblazer
Doesn’t matter since you’re going to flush with clear water again after sanitizing, correct?
You might be the best to determine what size valve you have since you can see the line. My telepathy isn’t that strong. Barring your ability to measure the line or cap, you could take the cap to the store and match it up.
Thank You, I was just hoping someone knew off hand with my back the less time on my knees under the RV the better 😁
