I never really solved the issue, but went at the rack with Q-tips and oil, and it does work better. But if a hard lump, like a tooth of the pinion gear, breaks off and gets stuck in the rack, it is a huge problem. You cannot get the top either up or down. It is not possible to enclose the rack & pinion more than it already is because the traveler has to slide the full length of the rack.
Okan-Star has it just about right in saying it is a weight issue. I use the Apex differently from most, always carrying one canoe on the roof and sometimes 3. Some of you may remember the Outfitter web site which showed the roof going up-and-down with an ATV sitting on the roof. Three canoes weigh less than an ATV. A canoe weighs less than the air conditioner, which is also on the roof. I've tried several methods for raising the roof with that extra weight up there, as the hand crank won't do it. A couple friends pushing up was the most commonly used method. But I constructed 2 air bags from the coated fabric used to build rafts, stuck those on opposite sides of the bed, and hooked them up to the 12 v air compressor. It takes less than a minute, and less than 10 lbs air pressure, to raise the roof by 15 inches or so, and after that, the hand crank easily completes the task.
