Dandy_Dan
Jan 29, 2016Explorer
If you have a 2 piece driveshaft, check the carrier bearing and U-joints. In the truck I had it ended up being a bad U-joint so I had all of them replaced with greasable joints. Problem solved for me. This is just FYI for you in checking. Good Luck
