Looking in to getting a coachman Catalina. Does anyone have one? What are the pros and cons? I want to do as much research as I can and want some first hand testimonials. Thanks all!!
Probably no better or worse than any other make in that price range. All the appliances are basically the same as are the materials used to build one. The big difference is the guys that put it together at the time. The trick is to find a floor plan you like and then go over that particular unit very carefully. I’m sure you will find people who will sing Coachmen’s praises and others who will condemn them.
