Deb_and_Ed_M
Jul 29, 2015Explorer II
Coil Spring Air bags - what PSI?
My 2014 Ram 1500 is a wuss. Squats like crazy under the puny weight (probably 1100# loaded) of my stripped-out Bronco 1200 popup. We added the Air Lift "sausage" bags that fit inside the springs, and that sure helps level out the truck again, but I'm curious as to what PSI other folks might be using? The truck still seems to sway back and forth a lot....
