2oldman's avatar
2oldman
Explorer II
Oct 15, 2013
Cold weather diesel starting
Tried to start the Cummins 8.3L in 28° weather, and it started, but shook horribly. I let it run for about a minute then turned it off. Restarted it and it ran fine. That was scary.
Talked to some truckers and called a Freightliner place.. they it was gelled fuel, and to use an additive. Got some. Hope tomorrow morning is better.
  • #2 from Idaho. Well, maybe it is something else, but there were no lights coming on.
  • Straight #2, Bio or a mix?
    No way straight #2 or even a low mix will gel at that temp.
  • 28 isn't all that cold for a diesel. I'm guessing the engine either had weak plugs or a weak grid (not sure which the 8.3l has). At that temp the engine should start right up with a good bit of noise, but not shuttering.
  • Trackrig wrote:
    28 degrees seems to be a little high for gelling problmes.
    I thought the same thing. Perhaps some engines are more sensitive.
    It should be about as cold tonight so we'll see what it does in the am. Like I said, once I stopped and started it, it was fine all day.
  • Additive like Power Serve will help, but 28 degrees seems to be a little high for gelling problmes.
    Bill
