myredracer wrote:
We have a Roadtrip grill and I removed the Coleman regulator and modified it to connect directly to a hose which connects to a quick connect under our TT. Fairly easy to do. I added the quick connect fitting by running a length of hose to a capped tee provided by the factory. I have been using this setup on 3 TTs now and it works well and is really convenient. We also have a campfire-in-a-can that uses the quick connect.
Not terribly impressed with the Coleman grill and the next one will likely be a Weber. Not sure if the same mod can be done to them.
I did a similar mod on my Weber Q, and it's very similar to your Roadtrip mod. Very easy to do.
