SoCalDesertRid1
Nov 28, 2013Explorer II
1stgenfarmboy wrote:That would be a demand of about 1400-1500 watts for the A/C. The 2000 watt generator should run it, but it won't run much else at the same time. Looks like a second generator would be needed, one for the A/C and one for everything else. Or, power the camper from a single Honda 3000 instead.
I stand corrected sir, at extreme outside temps the AC will pull 200-250 watts more than at 65*, sorry if I mislead anyone.
the blower motor will stay the same no mater the temp, the compressor is the culprit for the added amp draw.
looks like a 2000 is on the threshold of running or not a mach 1 in desert conditions.
16.7 max and 13.3 run is what im seeing on a 2000w Honda, is this correct.
I used a much less expensive Generac 4000 and it powered my 13.5 Btu A/C, microwave and the rest of the camper. It is loud, but then again, so are all the dirt bikes, atv's, buggies and desert trucks that are used in the areas I camped in.
44,068 PostsLatest Activity: Jun 20, 2026
