2015 Ram 5500 HD 4wd Tradesman 60" CA
Crew cab with 197.4" wheelbase
19,000 lb GVWR with 26,000 lb GCWR
Cummins I6 6.7 liter diesel
Chassis cab tune 325 hp @ 2800 rpm and 750 ft-lb @ 1700 rpm
Aisin AS69RC 6-speed automatic
New Process NV271 manual transfer case
Magna Steyr 275mm 7250 lb FAWR
Dana S14-111L limited slip with 4.44 ratio 13,500 lb RAWR 14,500 lbs OEM rated
Palfinger Badger low sill flat bed
DeeZee 36x18x18 under bed boxes
Curt Double Lock 30K lb gooseneck
SuperHitch Magnum 20K dual receiver
Short range FastGun turnbuckles
4'x7'x3/4" horse stall mats
Unloaded weight 10,225 lbs
Loading things up
