DM6156
Dec 11, 2018Explorer
A few things I've learned in my 1st year of TT ownership first hand or from talking to fellow campers where I've stayed.
1. Keep in mind the destination.
- Some campgrounds have limited space for larger RV/TTs (i.e. state parks)
- Some campgrounds have limitations of type of TT (i.e. fishing bridge in yellowstone national park does not allow tent campers due to bear activity).
- Some campgrounds have limited pull-through, you'll need to back that thing up! Some people don't like to do that.
2. Just because your tow vehicle says it can tow the TT doesn't mean it can do it WELL. Sure a 3500lb rated vehicle can tow 3000+lb TT on flat ground, but may (will) have issues going up/down mountain roads, especially steep ones.
3. Sway control / WD hitch is your friend. Dealer tossed mine in free when i purchased TT. Ask for deals!
4. You tube is also your friend. Good videos showcasing models (can save you 1-2 hour of wasted drive time).
5. Manufacturer websites are your friend too! Research specs, including inside hight! I looked at one TT and really displiked it because the ceiling was so low in comparision to others with similar layout/features - it felt really claustrophobic.
What I did, check all local dealer websites looking for ones that fit my criteria. After narrowing down list, went to manufacturer websites to get more detailed specs. Then went to visit local dealers to see them first hand. Sometimes, pictures don't show entire story.
44,066 PostsLatest Activity: Apr 16, 2026
