Wizbangdoodle
Apr 06, 2016Explorer
Is there any smoke out the exhaust? Are you running any kind of tune on it? Do you have a monitor/tuner that you use to monitor vitals like EGT's and other temps? Can you read codes and are there any?
If you took it in to a dealer, they should be able to run a contribution code check on it and see if all your cylinders are healthy. Most obvious answer is head gaskets like stated above, but it could be something else like EGR coolers. Get ready to open your wallet.
