dakonthemountain wrote:
JJ, Sounds good. The only advice I'd offer is the length. If you are taking the camper off the truck you will have a better time if the entire thing is level. What I mean is if the pad for the camper is level, but shorter, and you have to pull out and off the pad on to a sloping (up/down/left/right)when pulling out from under the camper you could have some issue. Just a thought. In any event good luck!
Dak
I'll have them double check but should be a straight level shot from pad to driveway, also a friend of mine is doing it he has a commercial concrete company so all I'm paying for is labor for the footer and leveling...
JJ
