jnjeter wrote:
We have a 2014 Passport Ultra Lite Elite . At the head of the bed, located against front wall is a seam strip 10" above bed base. Our temps are in 30's-40's and the section below seam is wet with condensation . The area above is dry. The outside is seamless fiberglass. Could it be due to omission of insulation in that area ? ....or ?
If it's under the mattress, it's condensation from body aspiration of moisture (sweat). If it's above the mattress, you have a seal failure issue and water intrusion. Have you maintained your seals in accordance with the builders guidelines?
It won't get better, only worse and needs to be addressed pronto or your RV will become a pile of rotten moldy garbage.
