OldShu wrote:
Tongue weight (326 lb) is going to be to high for your TV limit of 350 lb. Generally the "DRY" list # is with no LP or battery on the tongue. 100 lb +/- and add a WDH of 70 lb. and you are at 495 and still have not put any inside the TT. It will be over 500 easily.
I hate to be the bearer of bad news.
Just to be clear, you are NOT bumper pulling this TT but have a receiver hitch on your TV.?
Do you have a budget in mind?
I thought part of a WD was to spread the tongue weight to lessen it? I must have been wrong on that.
Yes, i had planned to use a 2 inch class III receiver. I have used my bumper ball to tow a small boat, sub 1k pounds without brakes on it but never intended tow tow a TT from the bumper ball. I had planned for the 7 pin Y plug from Nissan, truck is pre wired and a Tekonsha brake controller.
