OldShu wrote:
Tongue weight (326 lb) is going to be to high for your TV limit of 350 lb. Generally the "DRY" list # is with no LP or battery on the tongue. 100 lb +/- and add a WDH of 70 lb. and you are at 495 and still have not put any inside the TT. It will be over 500 easily.
I hate to be the bearer of bad news.
Just to be clear, you are NOT bumper pulling this TT but have a receiver hitch on your TV.?
Do you have a budget in mind?
I was re-reading this and I went back through my notes and looked over what I had noted for the tongue weights. The dry tongue is listed at 320, which to your point is too close to my TV max tongue listed at 350 pounds anyway. After checking again with the WD hitch information, I also know that the WD won't reduce tongue weight at all so my TV max TW stays 350 and would be way over.
I took another look at the RPODs per an earlier recommendation, there's an RP 172 with sleeping for 4 and a dry hitch at 243 lbs. It's wider and would appear to have a larger frontal area, making pulling that a no go either.
Again, I appreciate all the education I have gotten from here.
