luggage wrote:
I want to up grade from a TAG pull behind to a 5th wheeler and I am getting different weights that I can tow safely. I have called Ford dealers, RV dealers and even the Ford Motor co and all tel me I can pull anywhere from 8000 lbs (I know this can't be right), 10,000 lbs to 12,000 lbs to 13,400lbs. I have a 2002 Ford Diesel crew cab w/70,000 miles,7.3L engine and a 3.73 rear end ratio. The Ford people told me the truck came with a standard trailer towing package. I am finding too many folks seem to throw caution to the wind and tell me "man you can pull anything with that truck" I know that's, BS. I want to buy something that I can pull on the flats and hills in Alabama but also pull in the mountains in Tennessee. Advice is appreciated.
Can Ford tell you what the actual "GVWR" (Gross Vehicle Weight Rating) is for your specific truck? Is there a sticker/tag anywhere that tells you? Check doorjambs, glove box, etc.
