Stay 1000 lbs below GCWR.....Stay below TV front/rear axle WR...weigh TV at CCAT with people/cargo for camping and add 5th wheel hitch weight to that...if one not installed....try and load a 100 lbs where the hitch will be before you weigh to get a better picture of axle weight on each axle...then you can apply the numbers to see what size trailer you can get.....Subtract rear axle weight from rear axle WR to get pin weight...Subtract TV total axle weight + 1000 from GCRW to get max trailer weight.....this is a starting point then apply all the number and make sure your vehicles fall in correct limits.....good luck
