jmartin99
May 02, 2014Explorer
Converter/Battery Issues!!
I just bought an old '83 Jayco 32' Jayflight TT. I have had shore power plugged into it off and on since I have got it home to get the radio and lights to work inside the camper. A few days ago I charged the battery with my battery tender and replaced the wire terminals that connect the TT to the battery. I then removed shore power and tried the lights and radio but they did not work.
If the lights and radio work with shore power, does this mean the converter is still working? Where is the converter located? I have found the fuse panel in a compartment below the stove, should it be in that general area?
Another issue I have is the water pump is not installed at this time. I should get the parts I need to reconnect it next Monday. There are wires to connect power to the pump at the back of the TT. Where is the switch located to operate the pump? There is a switch under the counter next to the stove, I am wondering if this could be the pump switch. There is also a very small push button switch above that switch, any ideas what it would be for???
Thanks for any help with my issues!!! I am learning as I go! :)
Jeff
Jeff
