busch2fan
Aug 12, 2010Explorer
LarryJM wrote:Jeffzee160 wrote:
While sort of slick for around $20 you can get a swivel stick rinser where the water doesn't come out of fixed holes like yours, but it rotates and washes down the sides of the tank evenly and is flexible so you can sort of direct it up or down some. The rotating part only has like two holes so the water really comes out at a very high pressure.
Instead of trying to reinvent the wheel this is something I would just buy that has been tested and proven to work.
Larry
Don't be too quick to desparange inginuity...
I bought one of those unit you showed...
1. The end of it was too big to fit past the ball valve in the toilet
2. The shut off valve in the wand broke w/in 3 minutes of trying to use it
I tried to go the cheap route... cost me in the end.
44,066 PostsLatest Activity: May 13, 2026
