Deewayne
Apr 02, 2011Explorer
The previous switch is the best you can buy.
Shop wisely and don't be afraid of using google. I think I found one from a Marine Dealer - $47. You will also need a Battery cable (about 15") to go from the neg. side the battery to the switch. NAPA is a good source.
I use one, but I installed mine through the top of the battery cover protruding upward (Large box w/group 27DS Batt.) I had to put a piece 2" x 2" wood into the opposite topside of the cover for spacing to hold the cover level.
It was a lot easier to cut plastic over Steel.
When you cut the cover make sure of your spacing. If you don't the cover may not go back on.
44,069 PostsLatest Activity: Jul 05, 2026
