HedoTravelers
Jun 11, 2011Explorer
As far as the cloudiness problem... if you used the traditional film, it should be almost clear as soon as you install it. If you used the vinyl stuff, and you did not use lots of soapy water when installing it, it may not clear up. If that happens, pull it back off and re-wet the glass then re-apply.
44,029 PostsLatest Activity: Jan 21, 2025
