monkey44
Apr 14, 2018Nomad II
If you need to raise you camper to clear rails or cab, cut three/four pieces of one inch composite decking and screw it directly to the bottom of the camper, front, rear contact point, and one or two in the middle, cross-ways on the bed, not length-ways. You can add glue, but that makes it difficult to replace if you ever damage a board. If you need more than one inch, then use 2x4 pressure treated, or 2x6 if you have a long bed camper.
Then, you're camper sits higher and right on the bed-pad, and it never moves. I've done this to both a Fleetwood and Lance. Sixteen years total, mountains, desert, highway, off-highway, whatever ... never has an issue with movement.
PLUS, it gives you ventilation under the camper, so it never sits in water.
44,066 PostsLatest Activity: Jul 25, 2018
