dixonce
May 28, 2017Explorer
Correct Truck
I am looking to purchase a Grand Design Momentum TH 376th. The GVWR is 20,000lbs. The truck I am looking to use for this is the 2017 F350 dually with the diesel. Do have enough truck once loaded with ...
donn0128 wrote:Trackrig wrote:
MFG Web site.
3,250# Avg. pin weight.
Bill
Read that as DRY pin weight.
If you never plan to add anything to the trailer, then maybe. After you load it it? Probably not.
With 20K GVWR that means fully loaded your pin weight could be over 4000 pounds.
A Ram dually with all the towing options might do it.
