dixonce
May 28, 2017Explorer
Correct Truck
I am looking to purchase a Grand Design Momentum TH 376th. The GVWR is 20,000lbs. The truck I am looking to use for this is the 2017 F350 dually with the diesel. Do have enough truck once loaded with ...
vonzoog wrote:
Thanks Cummins12V98,
Your response is pretty much what I was already thinking. Was hoping to hear that someone else has been there and done that. I had not thought about adding the Bilstien shocks, but sounds like a good idea.
My current toy hauler is squatting the truck about 3 inches in the rear and I am noticing my headlights are a little high. Going with the Momentum would/should squat the truck a little more. The added pin weight had me more concerned than the gearing requirements.
Would adding the Bilstiens now make a noticeable difference over the stock setup?
Thanks again,
