thib2722
Mar 23, 2014Explorer
One major issue to contend with with fiberglass is delimitation. If water gets inside, it will separate. Stick and tin is susceptible to leaking as well, but it is easier to fix. The tin can be removed, whereas local shops cannot fix fiberglass unless they replace the entire wall. No shops here in the South have the ability to rebuild fiberglass walls. I'm on my third unit, and the second was fiberglass. We had a delamination issue and the entire front cap had to be changed. Thankfully it wasn't a side wall, because that would have been a much bigger issue.
44,071 PostsLatest Activity: Aug 30, 2026
