kohldad
Aug 13, 2016Explorer III
I really don't think the water tank is supported by the floor but held up by straps. Easy to tell by opening up the access panel and looking in the area. Same goes for the black and gray tanks which could also pose a problem.
On the cord, yes, if you lay it on the fender well, there is the chance it can fall and get under the camper as it rocks while driving. Easy to resolve though by putting on a hose clamp that is one or two sizes larger than needed for the wire. Then you can use the hose clamp's tail as a hook in the side pocket hole before setting the camper down. This would hold it up and out of harms way.
44,066 PostsLatest Activity: Jul 25, 2018
