Christl
Oct 22, 2015Explorer
Reddog1 wrote:
Seems to me, if you were to put a piece of plywood/strand board, 1/2" thick x 12" to 18" wide in front and to the rear of the wheel wells, with a full sheet plywood on top, it would pretty much bridge the crown.
Wayne
Hi Wayne: I like your idea of putting the narrow piece under the 4x8 plywood sheet as the full sheet will tend to bridge from there to the top of the crown and will end up providing the greatest amount of flat surface. I will check if as it may need to be as much as 18" wide to preform properly. cheers christl
