Hermes1 wrote:
spoon059 wrote:
If you leave the Cummins stock it will never allow itself to get too hot. It will defuel if temps ever got high enough. The only temp you need to worry about is turbo EGT's. The manual tells you to let the turbo cool down for a couple minutes after a hot haul. Generally for me, that means I just leave the truck running while I refuel and I leave the truck running while I disconnect the camper.
True but I seem to recall reading that after a heavy tow or haul, the drive into and through the campground to your site is enough to bring down those temps. Of course nothing wrong in doing as you suggest, but may not be completely necessary.
The problem with the campgrounds around here is you have to check in first before you can drive to your site.
