Wolfrequiem
Oct 29, 2017Explorer
Dayton Fayette Axle Identification and Questions
Hello, All,
I just purchased a 20' camper frame from the 1970's to build a tiny house on (the deck actually measures 18' 6", but I think they listed it as 20'). I live in an older Terry fifth wheel now and that is getting old during winter, so I'm hoping to build myself something--as/if funds allow--to do a little better. The camper frame has the Dayton Fayette axles and heavy duty suspension. The hubs are stamped 5-1-70, and they have the 10" brake drums, with brakes on *both* axles... and I'm desperate for some help identifying the axle rating and scoring a few part numbers, as well, if any of you can help me.
The first question, then, is what are the axles rated at?
The diameter of the axle and spindle are slightly more than is typical for 3500lb axles (the 2 3/8" and 1.719" normally quoted numbers--my axle is 2 3/4", or a hair more, and my spindle is 1.732", as best I can tell, on both), and, having read that some of the older models were actually rated at 4100lb, I'm wondering if these are (I need to know before I build on it, is why I ask). To add to the confusion, I've also read that some 5200lb axles actually measure in at the 2 3/8" diameter range too, so I don't know what to assume I have. With the heavy suspension and it being older, I'm thinking more than 3500lb, but can't be sure, if you could help me identify the rating. The coupler, if it matters, is a Marvel Class 3 unit.
The shocks I am getting/that I think will work are the Lippert LC283280. At least, I'm hoping those work.
Second, the trailer is missing four of the tapered 60° 1/2-20 bolts for the hubs, and I'm struggling to find replacements. I've searched and found the various places that sell the bolts of this type that are often linked in the forums, but they sell them with a *fine* thread, and I need *coarse," RH. Anybody know where four could be scored? And a salvage yard is fine.
Last, is there a PDF with the brake diagram on it, so that I can compare to see what might be missing? There are no lights at present, and the brakes have been cut, but I'm going to buy some lights and a harness and rewire it all, and need to know what to look for on the brakes when I inspect them, to know what needs to be replaced. Or if there are just some general things you know of—at first glance, they all seem to be there, though one scrubs when one wheel turns. I am told Dexter makes replacement parts, and have contacted them, but they're not proving very helpful. (Also, my idea of testing them is to wire the trailer, then hook it up to the truck, jacking up each tire or axle and spinning it while someone engages the brakes, to see, first, if it stops the tire and, second, if it releases it; does that sound like an appropriate method for testing them?)
And do any of you know the style or replacement part numbers with Dexter for them?
Anyway, any part references you can give on the bushings or seals or anything, please feel free. Anything you can link me to would be awesome, as well, shematics-wise, etc. I have ordered some seals already that I think will work, and have a shock in mind I'm going to try, as well, but am not sure about Class D or E on tires to order them. As for swapping the axles out--I don't have funds for that with all that I'm in for already, but, given how few times the thing will be on the road, would just as soon not spend the money on it. I mean, I may move it twice in my life, if that.
I am adding photos. I'm not sure if you can see it from the pictures, but the two wheeled axles are connected to that third axle between them, which is hooked to those bumpers between the wheels. It's weird, or, at least, I've never seen it before, but it looks heavy duty.
The main thing is, I'm not even sure what the devil I have or what you would call that suspension to even search for stuff on it. "Dayton Fayette" I can do, of course, not that that is helping any.
Thanks, in advance,
Gary
Thanks, in advance,
Gary
