lawnspecialties wrote:
Following Up. If you can get the actual pin weighed for a real world number, you may be OK for an SRW truck. GD lists the pin as 3250 lbs. If it really is close to that, you can get an SRW 1 ton; especially since you said you won't be towing too often.
But if you absolutely don't mind getting a dually, do it. As donn referred, its much better to have more than enough truck.
The pin weights listed by GD are EMPTY - not an accurate reflection of what it will be loaded. Use 23% of the GVWR of the trailer as a working number. I wouldn't consider anything less than a F350/3500 dural rear wheel for a Momentum. Safety first!
Rob
