norfla71
May 30, 2013Explorer
Decreasing towing fatigue in Ram 3500 4x4 single
I pull a 34' Salem toy hauler and, lately, have noticed the truck loaded or empty is not nearly as stable as when I bought it. It currently has 72,000 miles and, aside from the usual suspects (ball joints, tie rods, bushings which will be inspected Saturday) it was never really that great to begin with. I have to fight the wheel for constant corrections. Every 4x4 I've towed with (2000 Super Duty previously) has been tiresome to tow long distances; my 04 2500 2wd was excellent and I could tow heavy and not feel like I had been to the gym for a couple of hours afterward. Tires are 265/70 Dueler Revo's, and I'm not overly impressed (stock BFG's were much more stable).
Questions:
- aside from replacing normal wear items, are there any aftermarket bolt-ons that will increase stability to near dually levels? A conversion is not is the budget. Things like a rear sway bar, front arms, adjustable trac bar, A/S tread tires, etc.
- are wider tires worse for towing than keeping close to the stock size? I'm thinking about bad weather and how a wider tire will handle sudden downpours we always seem to get here in FL. I don't go offroad much, either, so popular 35" and 37" upgrades won't work for me.
- speaking of tires, any good luck with Nitto Duras v/s the LTX A/S?
- I hate the way the pin always slams around in the box on rough roads or when taking off from a stop. Other than shelling out big dollars for a Fifth Airborne or equivalent is there a lower cost solution? I'm running a Reese 15k Pro.
Questions:
