full_mosey wrote:
I read here very often that the WFCO charger dries out regular flooded batteries(FLA) which results in exposed plates and permanent damage or destruction.
Is there any situation where the WFCO's 13.6V could cause an AGM to vent and dry out?
I don't see how a WFCO could dry out any battery as it rarely if ever bulk charges at it's claimed 14.4 volt bulk charge voltage ... the most I've ever seen from mine at the battery terminals is ~ 13.72 volts. Undercharging a depleted battery, AGM or flooded, however will lead to excessive sulfation and ultimately premature death. For those of us who normally camp on electric sites and therefore rarely deep discharge the battery this isn't much of an issue as the battery is as likely to die of old age. My own 9 yr old flooded G27 Interstate is a case in point, has always been maintained by WFCO converters but still holds a full charge just fine and rarely requires watering ... but it also rarely see deep discharge. That said, this past fall I turned my current WFCO off permanently and now use a CTEK portable charger that does do a proper 14.4 volt bulk charge and lo & behold the battery is now performing even better ... after surface charge wears off it holds ~ 12.82 volts unloaded for weeks while sitting on my workbench. :B
