Huntindog wrote:
FishOnOne wrote:
Huntindog wrote:
FishOnOne wrote:
Huntindog wrote:
I'm glad my GM doesn't work like that. I have been waiting for the message and then adding 2.5 gallons. I don't want to fill it as the high heat here in AZ rapidly accelerates the DEF degradation.
I don't drive it enough to use it up all that fast sometimes. DEF that has gone bad in the tank pretty much means a tow truck to the dealer. Not a warranty item either.
I'm glad my Ford doesn't have the DEF Poor Quality problems. :W
Fish,,,, You do know that DEF will degrade at the same rate no matter which brand truck it is in right?
And you should also know that DEF that has degraded will no longer do the job for which it is intended right?
So degraded DEF in ANY brands tank will cause problems..... The Fed simply won't allow a DEF system that is not functioning properly to let the truck run and pollute.... Even in your beloved Ford.
Hate to break it to ya.:B
Nothing earthshattering here...
I simply fill my DEF using the Motorcraft spout at every oil change. It's that simple... Oh, and no DEF poor quality messages either... Sorry wrong brand that's a GM thing. :W
Troy, you just refuse to get it.
I can and did used to fill my tank at oil change time. Then I found out how high temps GREATLY reduce the life of DEF.. And since I am in Phoenix AZ, where high temps are a fact of life, and I don't put that many miles on the truck, I decided it would be prudent to just put in 2.5 gallons whenever the warning message popped up. This will keep the DEF pretty fresh and avoid it going bad in the tank... It would go bad in a Ford tank too under the same conditions... I was surprised to find by reading here, that the Ford system won't allow for this. The tank MUST be filled all the way to clear the message.... That could be a problem for me and others like me.
And if your DEF should go bad in the tank, the truck will not run for long.. And it is NOT just a GM, Ford, or Dodge thing. It is the EPA regulations. Sorry, your precious Ford is not exempt..
Dog,
Yes we all know that DEF has a shelf life and yes we all know that the shelf life is reduced with elevated temperatures. Having said that, my point is the GM trucks are prone to DEF contamination problems and it's a pretty common discussion. Your environment is not unique and it appears the Fords and RAM's are not as sensitive to the DEF contamination like your GM truck so I simply fill and don't worry about it like you have too. :B
I suppose if I owned a GM truck I would partial fill to keep it fresh and avoid filling DEF from a truck stop like the plague.
