keymastr
Nov 08, 2014Explorer
Vacuum bonding uses glue/resin between the layers and then applies a vacuum and heat to make the "sandwich" cure. It is very solid but as mentioned leaves no room for wiring after the fact. If that method is used wiring is done ahead of bonding.
44,071 PostsLatest Activity: Aug 30, 2026
