sleepy
May 19, 2013Explorer
RichieC wrote:
I like that concept but struggle with the idea that the jacks would suffer a degree of twisting.
Have you used it yet?
How far out of alignment can it be?
Good question... I should have explained better.
Yes... I have used it and it works very well... now the hardest part of loading is remembering to switch the lic plate and to plug up the TC to the trucks 12VDC system before I finish loading.
I have never been 1/2" out of alignment when loading in the 10 years we have owned our T/TC...
I have a little more than 1" clearence to my extended jacks on each side of my duallys. It sounds scary but after a few time it won't bother you, The jacks turn out to be good centering guides.
I use my side mirrors... I watch the outside of the camper under the overhangs and keep them even with the inside rear of the bed sides........ and, at the same time maintain the space evenly between the jacks.
This project started to keep the TC from sliding around on long trips... you know the times when you check the tie downs and one side is loose... the other sides tie downs are tighter than banjo strimgs.
The slope guides are really for when the camper is almost on the trucks bed... I didn't want the camper to sit on top of a low bracket, but wanted close tolarances... now it would be impossible. I'm sure that you noticed I didn't bother to cut the risers off, they aren't in the way.
Thanks again,
Sleepy
