ktmrfs
Oct 12, 2021Explorer III
Dicor on the info sheets will tell you that Dicor sealant on a EDPM roof WILL cause some " buckling" etc as the sealant cures and usually will go away. Part of the reason is the sealant has hydrocarbon solvents (naptha etc) that Dicor says will cause this to happen. That is why the say to never use such solvents to clean the membrane. I suspect the solvent in the dicor is controlled and designed to not cause damage but to aid in adhesion.
44,071 PostsLatest Activity: Aug 23, 2026
