SidecarFlip wrote:
Whatever, I bet you blatantly ignore the advice of medical professionals concerning the Wuhan Flu too. I don't reside in a glass house but obviously, yo do.
Here is what I don't understand about you. If you are so concerned about air quality, then why do drive a truck that is pre-2004 or even pre-1998 regulation standards? On top of that, you said you had it "chipped" and increase its power output(more fuel) in another thread which increases it's emissions out put even more.
Because you have a HEUI fuel pump that has much lower pressures than modern diesels, single fire injectors that allow for a lot more un-burned fuel than modern multi-fire injectors, and a fixed geometry turbo than cannot alter the amount of air that goes in as effectively, your truck emits more than even a modern deleted diesel. Even more so with the power adders you added to it. So you yourself would not be legal in accordance to your year model if you strapped it down to a dyno and your truck emits even more yet you are chastising them. I don't get it....
And before you try and say that your power adders do not increase emissions, I am going to call BS on that. Also, because of your HEUI pump uses engine oil to get its pressure which puts a great amount of strain on the oil, you have to change your 17 quarts of oil three times as often(every 5k) versus my 12 quarts of oil(every 15k) making even more pollution. So not only does your truck emits more than mine, it also uses more fuel, and three times more oil.
