Cummins12V98 wrote:
I was referring to a few pennies saved per gallon.
The difference between $2.59 and $2.19 is not " just pennies", and is a $.40 per gallon difference which is a quarter, dime and nickel. Also, when was the last time you just put a few gallons in your tank? So why look at it as per gallon rather than in tens of gallons when you are more than likely going to be putting more than 20 gallons in your tank each fill up?
Cummins12V98 wrote:
I KNOW my truck and RV WILL fit at ANY truck stop. If I take a trip off the freeway to the less expensive station they may not be easy in/out! That right there is worth $12 to me!
Which is why I said to each their own if they wish to save money or not. I was just saying that most your "just pennies" comment is false since it is way more. You quoting the $12 I stated is admittance that it is not "just pennies". Also, I am not just saying this for those with their RV's either. I am stating this for EVERYONE with a diesel loaded or not since it is true that diesel is cheaper away from major highways where semi trucks frequent.
Cummins12V98 wrote:
The fact you get fresh clean fuel at MOST all truck stops is worth $12 to me.
Uhm..... Fresh clean fuel????? Wha???? Oh I have got to hear the theory and science behind this.
