GoPackGo wrote:
"On a diesel engine the turbo is on there to just keep EGT and emissions in check."This is the first time I have ever seen a statement like this. Turbos have been used on diesels since forever to boost HP - John Deere tractors, semi's, etc. Long before there were any emissions standards at all.
In fact, possibly the coolest diesel car in existance - the Audi R18 Le Mans racer, gets approx 500 HP from a 3.7L turbo V-6. I doubt that the turbo is on there for emissions reasons.
I'm really not trying to be argumentative as I assume there's a little more to your statement. I'd really like to know what you mean.
Tim
You missed the EGT part Tim. Let me try to explain:
I can add a lot of fuel to a diesel to make a lot of power. Past a certain point the combustion chamber and everything in it will get too hot and fail. Pistons melt, rings get red hot and head gaskets burn.
The turbo is there to prevent that and it adds air to clean up emissions. The more boost you add the cooler the EGT will become because you are adding air to cool things off.
Here is a discussion about turbo boost on diesels. It does a better job of explaining it.
My point is, there is a big difference between a turbo on a gasoline engine and a diesel engine.
