ab257
Sep 24, 2016Explorer
I like my diesels power, but modern diesels are very fragile. Get water in the diesel and you are looking at a 4,000 dollar injector and high pressure fuel pump replacement. If you can find someone able to work on it when you are on the road. A shorted high temperature sensor shut down the truck and left us stranded by the side of the interstate, with a 2 day delay and $1,000 bill, and another $600 bill to replace the other 3 sensors before they short out. Also found out even without the camper a dually diesel is too wide and too heavy for a flatbed/wheel lift. Don't know what would have happened if we were off road in the back country. 150 dollar oil changes every 5,000 miles. $135 fuel filter changes every 10,000. Ford's are having rocker arm replacements at 100,000 miles. Most work requires cab off procedures. I'm not sure modern diesels are a consumer product anymore, but are limited to companies that can afford the downtime and repair cost. And if you take off the emission equipment and tune the truck you can burn out the cylinders. And never buy one used because the regular maintenance is so critical.
44,060 PostsLatest Activity: Mar 26, 2026
