KD4UPL
Aug 28, 2016Explorer II
Depends on the tire size and transmission ratios. They're likely pretty similar. Fuel consumption will be worse not towing. Towing it might be similar. It depends on how fast your going in which gear and what RPM the engine ends up in. You will turn more RPM to go the same speed.
Generally it should pull a lot stronger and accelerate better at the possible expense of some fuel.
44,071 PostsLatest Activity: Aug 30, 2026
