SoCalDesertRid1
Aug 28, 2016Explorer II
ShinerBock wrote:X 2
The formula for engine rpm is as follows:
(Axle Ratio x Vehicle Speed(in MPH) x Transmission Ratio of Selected Gear x 336.13) / Tire Diameter = Engine RPM
Just plug in the numbers and you get what rpm each rear gear ratio should be at a certain speed.
The worse fuel consumption depends on many variables, but yes when towing a shorter gear ratio(higher number) will generally have better fuel economy than a taller gear ratio(shorter number) when towing.
44,071 PostsLatest Activity: Aug 30, 2026
