lenr
Aug 29, 2016Explorer III
From memory, Ford chassis cabs use the 225/75-19.5. One would guess that will be the tire on the 2017 F-450. Because of the skinny cross section it barely turns any slower than the other size tires that Ford uses. Years ago I came across a GM white paper that made the case that the diesel engine is more sensitive to increased fuel consumption at increased rpms than is the gas engine. However, I would suspect that modern turbo controls may mitigate some.
44,071 PostsLatest Activity: Aug 30, 2026
