OH48Lt
Jun 03, 2014Explorer
From 2005-2007, the only differences between a F250 with the 10000 lb and snow plow packages and a F350 SRW is the rear blocks, the sticker on the door, and the badging. The F250 with the camper package adds the rear sway bar, it already has the extra rear leaf spring if it has the 10K package. Same axle, same frame, same brakes, same suspension as the F350 SRW. In those years, you cannot get the 10k package and get 20" wheels, those de-rate the GVWR. My 2005 F250 10K/snow plow package equipped came with 10 ply BF Goodrich tires on 17" steel wheels.
There are a lot of F250's out there that were not ordered with both the 10K package AND the snow plow package. The suspensions will be different on those trucks. So, you must know what flavor of F250 you're comparing against a F350.
