romore
Mar 24, 2018Explorer II
10,000 lb is the upper end for an F-250/2500, if you want to go bigger then you need to look seriously at a 1 ton. A fifth wheel puts about 20% of the weight on the pin so maximum payload becomes a factor. For your intended use you will also be a lot happier with diesel, you will pay a premium up front but it will even out in the long run.
44,068 PostsLatest Activity: Jun 17, 2026
