Ron3rd's avatar
Ron3rd
Explorer III
Nov 11, 2018
Differential Lube for 2016 Ram CTD 2500
As I mentioned in my other thread, I'm getting ready to change the diff lube in by 2016 Ram 2500 and would like some recommendation on gear lube.
I was looking at Mobil 1 Synthetic that meets the Ram GL-5 spec but notice it comes in 75W-90, not 75W-85 as recommended in the manual. Is this lube OK to use?
Just curious what others are using.
Also, according to the manual I do not need a friction modifier.
Update: Actually, my manual says to use 75W-85 in one section and 75W-90 in another section
I'm 2WD so I only need to do the rear diff.
  • I think you may also find it says to use 75/140 someplace. If you tow heavy in the heat it's a good choice.
    I often tow in the desert and use it year round.
  • I have a 3500 pulling heavy so I run 75/140 severe duty. There is not much difference in the weights you mention, go with either.
  • Ron3rd's avatar
    Ron3rd
    Explorer III
    Thanks Scott
    What's weird is one section of my manual says to use 75W-85 and 75W-90 in another section.
    Mobil 1 Synthetic OK? That's what I used in my last truck.
  • Yes 75-90.
    No friction modifier (your diff doesn't have a clutch)
