wmoses
Oct 27, 2013Explorer
Difficulty removing lens off LED lamps in Flagstaff 27 RLWS
My RV has LED lamps as shown below. If you have these lamps - What is the best way to remove the lens?
I need to remove the little styrofoam debris trapped there. Gently prying I was able to remove only one lens. The others hold on so firmly that I don't want to rip the fixture off the ceiling. I used a small screwdriver at the little slots (2 each side) but based on the design this is not the solution (hence the failure of the others). The slots are not where the little tabs on the inside of the lens are. Besides, the screwdriver puts little dents in the ceiling.
