honda1
Feb 17, 2017Explorer
dino oil vs synthetic mpg
has any one when from dino oil to full synthetic oil & had better m p g & what oil & how much better m p g did you get ? i have 2011 chevy 2500 Duramax pulling 35 ft 5th wheel..
Cummins12V98 wrote:
I run the 15-40 AMZ/OIL Diesel Signature Series in my Cummins. Oil is still in great shape at 15k with FleetGuard filter. This sample was at 45K on the clock.
ktmrfs wrote:FishOnOne wrote:ktmrfs wrote:
mfg are slowly switching to synthetics to get the best mileage possible for EPA testing, along with the 0W oils. Now, the EPA test is a short time from a cold start. and they are worried about 0.1mpg differences.
So.... do synthetics improve mileage, yes, but not likely enough that you can tell, and the biggest effect is likely in short trips in cold climates. long trips, less so.
synthetic advantage is more in engine protection and cold temp starting not mpg improvements. and given todays engine longevity, not sure there is a payback. your choice.
Back in the 1960's living in the midwest and not having access to a garage or a way to plug in the block heater when in college, I used conoco DN600 polar start oil in the winter. not sure if it was a synthetic or not, but at -40F my car, and others that used it would crank much faster and usually start better than others running 10W-30 at the same temps.
Manufacturers are switching to lower viscosity to improve fuel mileage.
agreed, that is one thing I pointed out. but they are looking for 0.1mpg improvements. how many of us could even measure that level of change? or have the cost/benefit pay off.
larry barnhart wrote:
I don't smoke or drink or chase the ladies so I have tons of money for oil.
Cummins12V98 wrote:
Some will say why do a sample every oil change like I have. When I go to sell this these reports will net me a higher price as they can see for a FACT the condition of the engine.
Some will say why do a sample every oil change like I have. When I go to sell this these reports will net me a higher price as they can see for a FACT the condition of the engine. The "Universal Average" numbers are averages of 6-7K oil changes. My TBN is strong and the Viscosities are strong along with flash points, these numbers are compared to the oils spec. You can see the previous two samples and how they have improved as the engine breaks in.
